I have a gixxer 1000 03' and it will not start. For some reason it is not getting any gas to the carburater and the fuel pump will not come on when you start it. Do anyone have any idea what could be wrong? I was told that the fuel injectors may be clogged. If so, what can I do to get them unclogged? Please help!!! We tested the fuel pump and it does work but will not come on when you try to start the bike. It just turns over.
bump I wish I knew the answer for you bro!!!
Obviously checked fuses and connectors??
Good luck!!!
Do you have a pclll? when I installed the full exhaust on my 03 I pulled the brown and black wire from the ecu and never sealed the hole in the connector and over a period of time the connection got corroded and the bike would not start. After cleaning the connector it never gave me any more problems.
do you hear the fuel pump prime when you turn on the power?
if not it could be:
--blown fuse
--burnt fuel pump relay
--tip over switch
--side stand switch
--dead bad fuel pump
I'd check each of these in that order
