Same everything minus the axle spacers. If you use your stock 750 wheel use your 750 spacers. If you go with a 1k rear wheel you will need the lt. side spacer from the 1k.
I assume a 00-03 750 and 01-02 1000 swingarm will bolt up to an 01 600 no problem? Im thinking about doing the swap for the bling factor. Anybody know if the 750/1000 swingarms are longer than the 600?
