I Found a set of 98 750 rims at a good price and wanted to know if they will fit a 98 600. Let me know what you think. Thanks
I *think* so....
As the swing arm is interchangeable, and as many people swap to a 750 front end, I cannot beleive they would go out an get new wheels....
The rear is wider on the 750 I beleive, again this is not really an issue as the 180 fits just fine - many run a 180 rear rather than the stock 190.
Bearded Admin call him Grizzly
yes they will fit, the fronts are the same the rears on the other hand are different but work, the 750 uses a 6" wide rim and the 600 uses a 5 1/2" wide rim
I was wondering if the spaceing is the same also because i can buy a 00 600 rim, rotor, cush drive, and sprocket for cheap i have a 1998 750
can i run a 180 tire because i am going to use the rim just wo mount another tire so when i go to the track to blow the hell out of it!!
So the 750 rims will work, but I should go with a 180 rear tire instead of a 190? Or will a 190 tire also work fine?
stick with a 180 for a better turn in
<font size="2" face="Verdana, Arial">get the spacers for the wheel you are using
