One on e-bay, complete, will it match up to my 89? A little modding to plastic is okay, i'm mainly concerned if it will bolt up to my motor.
any help appeciated, thanks.
ronnie
Discussion Starter · #2 ·
Guys, the bid ends in 9 hours!!!!!
I need to go to work and can't bid from work. Any help appreciated.
thanks, ronnie
It will _NOT_ work correctly if you are using the stock oil pan. (There is more to changing this than meets the eye. You will have to ask Jeff for all of the internal differences.)
You will probably get it to bolt up but you _WILL_ have exhaust leaks _AND_ it will touch the oil pan.
I am basing this on my US bikes. Is your 89 a 748cc?
J
[ 03-06-2002, 01:25 AM: Message edited by: Jason L ]
Thanks. I didn't bid on this anyways, as I dond't have the time and I wasn't sure if it was going to fit, bu tthanks.
And...yes it is a 748cc, the Candian 750's, (i believe), i might be wrong were unchanged from the US specs.
thanks, ronnie.
