i need to know what wheel bearing to use with 92 750 wheels on 86 1100 forks i made bearing spacers cause the bearings are way too big for the axle it works well but id feel at ease using the right stuff any help??
the bering you are looking for does not exist.
the 86 has a 15mm front axle, the 87 has the 17mm axle, and the 88+ has the 20mm axle.
for the 17mm there is a special bearing you can get for the swap, but for the 15mm there is no bearing. all you can do is use the spacers, or swap fronts.
You can get that bearing all you do is go to napa and they can get it for you.They have a bearing book. It is a altenator bearing that will work.I just got them for 88 750 wheels to use on my 1100.It is a good sealed,high speed bearing.
