Hey guys just wondering what map for the PC3 from the Dynojet site everyone uses on their K3 1000. I have a Yoshimura Full System with K&N filter and TRE. I am using M314-014 for Yosh full Duplex system and stock/aftermarket filter! There is another M315-524 European Model,TRS Muffler, Yosh Full System and Stock or Aftermarket filter! Has anyone tried one compared to the other and made any adjustments. I am told that at the exhaust tip there should be no build up at all of carbon. They say to lean out the map you have chosen until this is the case! Mine has some build of black stuff which i am assuming is carbon???
Any suggestions for getting rid of this "black stuff" in the exhaust tip or is this normal? I am going to download the Accelerator pump feature, Is this easy to use and does it help? Also I can't find the Ignition advance option on my PC3 USB Do I have to download this as well? Ignition Advance feature do anything for performance? Thanx in advance!
