1 - 20 of 31 Posts
I had the Battery on a trickle charger for winter when i put the battery back in i connected the battery the wrong way round sent a shower of sparks and now have No life at all !!!
I Think it's the Main Fuse but where is it?
or does anyone no what else it could be?
Also my brakes have siezed up :( my Poor poor Gixxer she needs some TLC!
Main fuse is under the seat...on the left side if sitting on it
I move away from the mic
This is what the fuse will look like.
You can get them at any auto parts store, even Radio Shack depending on where you live.
Discussion Starter #7
I Found it! it's not blown! :-S
I had a 20Amp & a 3amp in a rectangle black box thing.
still as I turn the Key nothing happens!
Do you have a multimeter?
Take the fuse out and read across it. Fuses can "look" good, but still be bad. Had this happen to one of other bikes that had the glass fuses.
Discussion Starter #9
No i don't have a Multimeter! i got one at my Army base, but not here!
could i have blown the ECU? i could try buying a new fuse tomorrow there cheap enuf anyway!
My m8 is getting his new R6 tomorrow an i would like to rideout!
Very possible something major happened if the fuse did not pop.
ECU blown, possible, no telling til you get into it and start checking the wiring and all fuses.
Tom im not being a smart arse but how did you manage to put it in the wrong way. Isint there a + and a - etched into the top of the battery.
two for the price of one ,,, speck savers.
Armi get round there and show this man where the fuses are and how to fit the battery. Its closer to you than me bud.
Discussion Starter #14
I'll Check the Green Plug aswell then chears!
I may have slightly.... just a little... not checked properly! :suicide:banghead
my Poor Gixxxr! i miss her the moody byatch!
u think i coulda Fried the Battery?
Just noticed where he is....lol if he really does need the help, i don't mind..
If you're stuck for a battery mate, i could come over and let you borrow mine, unless you have a car to jumpstart it :shifty
I had the same problem. It was down to conector blocks that were all full of blue stuff (corrosion),Id wager thats the problem.
Discussion Starter #20
I Got my hands on a Multimeter!
The Battery is a bit low but still charging!
The Fuses are fine!
I've given her a wash to to make her feel better, but she still won't speak to me, I checked the Green Cable under Tank, looked Fine. I tried unplugging my Alarm, checked everything I can think of!
Needing More ideas! You Guys are great Thanks a lot for your Help very much appreciated!
1 - 20 of 31 Posts
