Someone told me that a good weight reduction can be had from replacing
the stock tank with an aluminum one.
My guestion is:
Where can i find one?
How much do they cost?
How much weight do they actually cut?
I don't know where to find them but i haven't seen any aluminum tanks. I have seen carbon fiber which would be lighter than aluminum. Good luck
Thanks. Yeah i've looked all over the internet and came up with nothing.
Hopefully someone knows.
Here is your "R"
I wouldnt trust an aluminum gas tank, sheets of aluminum are very weak and can rupture easily. Imagine you low siding and your tank scrapes the ground and sparks a fire.
Yoshimura made them. I've seen two, literally. Very rare item. They were at least a few thousand each. Simpler solution is a composite tank that can be ordered from a few manufactures. Build quality varies. Best place to lose that weight is in the wheels first.
Discussion Starter · #6 ·
I found a CF tank for $1050. OUCH!!!! The only thing that worries me is that if i ever lay the bike down that tank is going bye bye.
Yeah i'm going to also go for wheels as well when i save up enough. 2-3K is not something i have laying around.
Bearded Viking Admin...
I had the tank off and emptied it for fuel filter cleaning recently amd really - it isn't that heavy. Not something I'd spend multiple 100 dollars on saving a couple of lbs on, at least... Hell, having it half full instead of full makes more difference...
