I was out ridding on the weekend and mid trip a coolant hose on my water pump let go. I trailered it home and the coolant that was hitting the ground mostly looked fairly clean/green. After removing the coolant hoses around the pump and dropping the last little bit of coolant out, I noticed the...
I have 2006 gsxr, I have had 4 oem gaskets put on, I’ve noticed it is leaking from exact same spot everytime. The last time I put on a gasket, I noticed by a screw hole there was some scarring on the metal and by the screw hole! Would this cause the leak? I contemplated putting a very thin layer...
I just replaced my oil pan and oil strainer('07 600). The strainer basically just slides into the opening and there is grooved stay. The rubber strainer didn't seem particularly firm in place, with a good O ring washer also installed. Does the pan offer any support once installed. Thanks a bunch!
Sorry for another oil post.....
I just did an oil change on my track only K8 and have filled with full synthetic but not started the bike yet as I'm a fraction short.
I've just had 4L of Castrol Power1 delivered and it's Semi-syn. 1st thought was to send back but after a bit of Google it looks...
Dear Mates, hope you are fine, I was hoping to get some advice regarding which engine oil I should use on my Suzuki Gixxer 155? I've 5000+ kms running and previously used Shell Advance Ultra 10w40 Full Synthetic. Hoping to get your expert solutions fast.
Thanks in advance. :woot
**In addition...
