1 - 9 of 9 Posts
Yes, I have searched both sections 09-11 and 12-16, for clear weight numbers of models (to compare) with no success! I would really hope there would be a simple sticky with ACTUAL wet weight and actual simple bolt ons dyno numbers!(((
Im looking for a wet weight of 12-16 1K with full exhaust and full tank!
If this was stated before please provide a link to a thread and IM SORRY for asking even tho I searched this!
My L3 w an Akra S.S. exhaust weighed 430lbs with an almost full tank as weighed on the local dragstrip's scale.
Discussion Starter #5 (Edited)
I know this section is for 11-16 but still want to post this in here, my bike specs (2009 Gsxr 1000):
-FULL TANK OF GAS
-Solo rear cover (rear pegs are in place)
-Stock (Ti) headers to SS Yoshi SINGLE pipe exhaust (Exhaust valve and Servo are in place)
-NEW road 5 tires
-No cut frame sliders
-Morimoto H1 v7.0 Hid projector
-Hid Ballast
Here is how I did it: I used TWO scales under both wheels but measured front first like 10 times by leaning bike on the stand and lifting it of the scales, then putting it up and balancing by two fingers, then did an average of numbers that i got, then did the same for rear.
Front - 106 kg
Rear - 97 kg
Total: 203 kg
Hand-Eye Coordinator
At last, someone is posting in metric
As for the rest of you gawdam imperialist mofos, may you all be reborn into the lower bardo realms a hundred thousand times
Apparently, someone doesn't know how to multiply by 2.2...
If that button's broken, you can divide by 0.454...
OP asked for weight, not mass. :lol
Reference:- 2009 Suzuki GSX-R 1000
TECHNICAL SPECIFICATIONS:
Length (ft) 6.71
Width (in/mm) 28 / 710
Height (in/mm) 44.5 / 1130
Wheelbase (in/mm) 55.3 / 1405
Length (ft/ft) 6
Length (ft/in) 8.5
Wet Weight (lbs/kg) 448 / 203
Fuel Capacity (gal/l) 4.6 / 17.5
Performance Standard
1 - 9 of 9 Posts
