What year rims will fit my \'90 750?
I would like to pick up an extra set of rims to mount my "track day" tires on. Rims from what years of GSX-R750s will be a direct bolt-on for my 1990? Thanks. This is my first post.
YAAFM Mod
Re: What year rims will fit my \'90 750?
Did we not just go over this?
88-93 750 rear - no mods (88-89 750 = 4.5in rear)
94-95 750 rear - change the wheelbearings
88-90 750 front - no mods
89-93 1100 rear - no mods
94-98 1100 rear - change the wheelbearings
89-90 1100 front - no mods
91-98 1100 front - change the wheelbearings
All 89-98 1100 and 88--95 750 use the same 310 rotors and rear rotor. The dfference is drilled or sloted front rotors. 95 750 wheels are the lightest. 93-95 750 and 93-98 1100 used six piston calipers.
Bones
G
Bones
<font size="2" face="Verdana, Arial">Don't you mean change the wheel spacers? The bearings are the same ID.
YAAFM Mod
The USD front end used larger dia axles and in 94 they switched to a larger dia drilled rear axle with the addition on the new style slide axle adjuster.
Bones
