well so far i've done full exhaust, jet kit, and changed the gears as well as regular maintaince. i'm thinkin new tires but any other performance mods you guys do that arent too complicated?
YAAFM Mod
Next I'd go with USD forks. It adds about 5lbs but much better set-up. If you use 91-92 parts they bolt on and use the same steering stops. If you go with the 93> forks you need to modify the stops but they still bolt on. Then get a quality rear shock from Fox or Ohlins. Some lighter wheels...Add some Ti...Custom paint...The list goes on and on..
Bones
You can't go wrong with omproving the suspension.
Then make it lighter, but that is an expensive bug.
look at my ost on modding oil coolers for some ideas.
-Karl
A good (and probably the cheapest bang for your buck) non-complicated mod is an aftermarket ignition advance plate (+ a few degrees).
[ 05-02-2002, 05:16 PM: Message edited by: 88/750 ]
