1 - 14 of 14 Posts
· Premium Member
The only brand I know of (that seems to be the most reputable) is the one you already mentioned. I replaced my fried R/R with a Ricks back in 2015 and haven’t had a problem since.
^It has mounting slots instead of holes, which would make it fit a wider range of mounts. Rick says it replaces 32800-47H00, 32800-41F11,32800-41F10, 32800-18H00, 32800-41G10 & 32800-47H10. The first is your OEM R/R. I think they all mount with two M6 screws on 80 mm centers. You can check yours. The electrical connectors should match.
1 - 14 of 14 Posts
