1 - 20 of 30 Posts
I'm asking specifically for 750 with no engine upgrades (heads and stuff I know nothing about) but any bike, stock, canned, jetted, full exhaust, internal work, 600, 750... if you have had a dyno run, please chime in.
I have Yosh RS-3 full race, airbox mod, K&N, custom PC map, my 98 750 did 117.4
I know it will push more though since there was no ram air effect in that run... the bike runs stronger than my friends 900RR and he pushes 120
i made 119hp. i was told i can make more with a custom map.
Thanks guys... keep em coming. I heard that if I was on a budget, a slip on and jet kit will do ok... looks like Katz's 94 rwhp proves just that.
1997 gsxr600 - 14k miles
1st dyno run - all stock w/ a yosh slip on: 85 hp
2nd dyno run - d&d ceramic header, venom carbon fiber exhaust, k&n filter, factory jet kit: 86 hp
3rd dyno run - after a valve adjustment: 96 hp
it sucks having next to no compression in one cylinder and low compression in the other 3 cylinders!
Mine dynoed at 93hp, but unknown baserun. Probably at 83 stock.
Just dynoed mine this weekend:
1997 GSXR600 = 91hp with K&N and Yosh Slip-on with 15K miles on the engine.
I'm told my carbs needs to get dialed in cuz my A/F ratio is all over the place. I might need a valve adjustment too. What sucks is I just had my bike tuned up.
G
got my bitch done bout 3 weeks ago....
98 750 with a K&N and D&D bolt on...20,000 kilomteres
before map 114.something
after map 119 exacatly.....yup im a happy camper
96 750 engine/ k&n/yosh bolt-on. get this,
one week ago - 117.8 hp
then on another dyno this week - 105 hp ???
no mods in between dynos and bike doesnt feel any different, 12.8 hp is noticable, its more than a 10% difference in numbers. so i gotta say, its tough to compare dyno numbers unless its the same dyno/dyno operator/etc.
Had my bone stock 98 750 dyno'ed at 116.8, but since then have added K&N, fully muzzy pipe, block off plates(took that PAIR crap off), 520 conversion. Still have to do the TRE mod and airbox mod. Will get dyno'ed again to see outcome.
Not enough...
My little feet can only turn the damd drum so fast.. lol
Anyhow... I will be getting on a dyno after the motor is back together...
I had my '98 750 dynoed at 122.7 HP with just a yoshi slip on and K&N airfilter in Dec of last year. Since then I put a full Akrapovic and pcII on, not sure what's it putting out now.
96 750 (36,000 miles), 108 hp on 'Factory' Eddycurrent dyno=124 dynojet hp (15% higher according to 'Factory' owner Mark Salvisberg). Yosh duplex, st-1 cams, airbox mod, 'factory' jet kit, +4 degree advancer, K&N filter, pump gas, hiflow oil filter, mobil 1 oil. I think it should do an honest 170mph (sigma sport speedo) and I will find out this summer.
Addendum to 108 Eddycurrent run, the jetting was very lean above 10krpm, I have since richened per shop suggestions and it feels much stronger on top.
guys with the 96-97 600's putting out 90 plus HP !!! Not bad dont ya think considering the 2003 honda F4i has only 95 !!! HAHAHAHAHHAHAHAHAHAAH
97 600 - Mine ran 88hp w/ full exhaust system (Leo Vince).
But I am above 6000 ft in elevation, so I lose quite a bit of power up here.
I dynoed my 97 600 a couple of months ago. It put out 85hp with a slip on. I wasn't too impressed. It has close to 30k miles though.
Dustyn
My 750 put out 120 at the tire on a low reading dyno.. We will see when I put her back together this time..
It will be fun.
1 - 20 of 30 Posts
