1 - 8 of 8 Posts
Hi everyone. I'm new here (but not new to riding). I recently purchased a 2012 GSX-R750 and I found this cable just sticking out of the right subframe above the rear brake caliper. Does anyone know what this is and what it does? Sorry if this has been asked before.
Automotive tire Motor vehicle Hood Automotive design Tire
Yes it's a standard battery tender connection. Also handy for checking battery voltage without removing the seat. The exposed pole is negative.
yup, what Bat said, trickle charger lead.. check to see if its connected to your battery.. if you don't plan on using it you may remove it..
2006 GSX-R 600
loose wire? bike is junk i'll give you $20 for it :)
that's just the battery tender hookup
Discussion Starter · #7 ·
I'll probably remove it when I have the time. I would like to leave it in there but living in an apartment, I don't have any electrical output to hook it up to a battery tender. Thanks for the replies.
1 - 8 of 8 Posts
