Petrol tap\petcock, replace or fit new kit to it.
Keep in mind that this model has a fuel pump built into the bottom of the gas tank. That adds another element to the simple broken petcock problem. What do you think?Petrol tap\petcock, replace or fit new kit to it.
Well aware of pump fitment ( own 3 srads ). If the petcock is working no fuel can flow when not running or being turned over. If the petcock allows too much fuel in it floods\hydro locks etc. Petcock is a cheap fix\ or check its functioning properly.Keep in mind that this model has a fuel pump built into the bottom of the gas tank. That adds another element to the simple broken petcock problem. What do you think?
Okay. Thank you for input. OEM PETCOCK is much different and more $$ than the generic red twist that I have currently from other owners.Well aware of pump fitment ( own 3 srads ). If the petcock is working no fuel can flow when not running or being turned over. If the petcock allows too much fuel in it floods\hydro locks etc. Petcock is a cheap fix\ or check its functioning properly.
Another clarification that might make a difference. The PETCOCK when turned off does a great job of stopping fuel from passing through it. Would you still suspect it be that with that said? ThanksWell aware of pump fitment ( own 3 srads ). If the petcock is working no fuel can flow when not running or being turned over. If the petcock allows too much fuel in it floods\hydro locks etc. Petcock is a cheap fix\ or check its functioning properly.
I attached a link to the exact one I am using on my bike. Pretty sure it’s For a f$&king lawn mower. Here it is :Petcock works on vacuum, there should be no on off.
" This may show my lack of experience but wouldn’t the float needles be able to counteract the excess fuel"
If its flooding nothing is going to stop it? as per your first comment.
Investigate issue and repair as required.
Cheap&nasty, does not belong on your bike. Will cause you problems. Twistedmister is also very knowledgeable on srads.I attached a link to the exact one I am using on my bike. Pretty sure it’s For a f$&king lawn mower. Here it is : View attachment 573861
hey there.
ordered new seat o rings. Viton 6mmID x2mm. Believe that’s correct size. Let me know if you have info off the top of your head. Appreciate this help more than u realize.
as far as petcock goes... look at what I sent sradmad600 earlier in this thread. Pretty much a lawn mower style. Don’t think that had a diaphragm to create vacuum.. what do you think? Seems like junk that could be causing the flooding perhaps. I went and ordered an original petcock.
when you say tap each needle seat o ring what do you mean. Thanks for the knowledge
Sam
As I’m looking at this cheap petcock, it’s connecting 2 fuel lines. 1 going from fuel pump to petcock and then petcock to carb.Cheap&nasty, does not belong on your bike. Will cause you problems. Twistedmister is also very knowledgeable on srads.
Thank ya! fuel pump hose attaches where?Pics should help with position of pipe.
The petcock sits just below the fuel pump, correct? The placement is foreign to me since I’m used to the aftermarket junkCenter of carbs, black connector tube ( push pipe onto).
Sorry to keep nagging you like this but hey not everyday I stumble upon this info!Center of carbs, black connector tube ( push pipe onto).
