1 - 20 of 91 Posts
Hello and Welcome to the K6/K7 600cc and 750cc FAQ and DIY thread. This thread is intended to get users off to a good start by putting information, both basic and advanced, at one easy to find location. The thread includes links to Suzuki specifications pages, picture threads, popular modifications and even some basic riding informaiton. Please read the links below before you get started off in the forum and remember to use the search function if you don't see what you're looking for.
Thanks and happy reading,
GDC Search Nazi Staff
BASIC INFORMATION
-Forum etiquette for new members
-New Owners
-Good Help, Advice, and Beginer Information
-Reminders of Why We Crash
-Get your Red R here
Suzuki's Official Specs:
-K6 600 - K6 750
-K7 600 - K7 750
Picture threads:
-General K6 pictures: [1] [2]
-Silver and White
-Blue and Whilte
-Black and Red
-Black and Silver (Black and Grey)
-Black and Maroon
-Black and Yellow
-All Black
-Black and Blue
-Red and White
Race Prep/Track Setup:
-Clutch Switch
-Suspension
-Geometry and Suspention
-Race Body Work
MODIFICATIONS
Exhaust:
-Exhaust Picture threads [1] [2] [3] <-- #3 is the most up to date :thumbup:
-Sound Clip Thread
-How to modify/shorten Yoshimura TRC can
Mud Flap/Rear Fender:
-Free/home made methods
Power Commander
-Button Advice
R1 throttle tube:
-DIY with Pictures
Grips:
-Swapping Grips
Levers:
-Pazzo v. CRG
-Pazzo Install
-Lever length advice
Rearsets:
-Gilles v. Sato: [1] [2]
Frame Protection:
-Sliders and crash protectors
-Race Railz
-Race Railz Install
Bar ends:
-Weighted Bar weights
SET:
-Removal with pictures
-Dyno before and after removal
How to properly adjust the SET valve for smooter performance
Air Filters:
-BMC Race debate
GP Shift Pattern:
-How-to with pictures
Bodywork:
-PIAA light in Race Glass
Maintenance
-Changing Spark Plugs
Dealer mode for FI light
Bleeding brakes.......
Moto Joe said:
the most effective way I have found (and I have tried them all over the years) for a radial MC system, with radial mount brakes, is NOT using a mechanical device (mity vac) like alot advise. I dont know why, but they just dont seem to work well on these systems.
Tie/tape a small cup or jar to the leg of the fork ABOVE both calipers bleeders. Also somehow suspend another cup above the master cylinder bleeder (tape it to the mirror maybe).
Now run a hose from EACH caliper to the cup on the fork leg, and one hose from the MC to the other cup.
Starting with the MC, JUST BARELY crack the bleeder screw. Just enough for there to still be a little bit of pressure requried to squeeze the lever, but open enough to pump fluid out. Do not open the bleeder too far, as you will just pump air from around the threads of the bleeder screw. now pump away till you see no air. No need to pump, hold, crack bleeder, close bleeder repeat. Just crack it and pump until you dont see air, then close it. IMPORTANT Keep the reservoir full.
Tap on the brake lines to loosen any bubbles that may be stuck to the inside of the lines.
Do the same for each caliper as well. Same technique and tap each line between each time you swap valves. Repeat at each of the three bleeders at least twice, if not three times.
While you are at it, also be sure to clean ALL brake dust off of the inside of the calipers, where the pads are. Any build up there will cause the brake pistons to stick, and can cause poor brake performance
Be carefull not to spill brake fluid ANYWHERE. It will eat paint. Clean up ASAP if you accidently do.
Thanks go out to all the Search Nazi Staff. We worked together in the background to get this together. I'll be adding to the original post as more information comes in.
Now nobody can say we don't do any good for the fourm. ;)
Great job, search nazi team
But remember, the day everyone search, and no one asks questions that have already been asked.
The forums will get about 2 post a day.
Which will not be fun at all.
Congrats again on the sticky
jasondd23 said:
awesome :D looks like someone did a little house cleaning.....there isn't a half page of "stickys" anymore
+1 Now we can see a lot more threads on the first page. Thanks for getting all the important things in one thread! :cheers
Ditchard the High Maintenance Squirrel
Looks good bro.
Since this good information is out, now we can continue the flaming and smartass remarks. :D
Awesome work on this, it makes the forum look so much cleaner now without the 10 separate stickies we used to have at the top. Nice job :cheers
1 - 20 of 91 Posts
About this Discussion
52 Participants
killswitch21
Full Forum Listing
