Have noticed recently my bike just sounds weaker at idle. Also, seems as though it stalls much easier now. Coming up on the 6,000 miles. Have a full exhaust, pair mod, ecu flashed ect. It just seems like it's getting weaker at idle. Any ideas on things to check?
Have you done your maintenance schedules properly? You're about 1,500 miles away from a spark plug change and you should probably check the air filter, as well.
  • Like
Reactions: TwistedMister
My L7 idle is a bit rough until it reaches about 50C, then it stays steady. Same behavior on stock bike + slip on and also after ECU flash.
My L2 is like this as well. Idle is rough and goes from 1100 to 1300 rpm until the bike is around 70ºC then it becomes steady. It has air filter, full exhaust and ECU tune. Never felt like it would stall though.
