Water pump fix gone WRONG impeller ground down
743 Views 7 Replies 5 Participants Last post by  Tom-s
Hey guys,
I'm new to this forum (hope I'm posting in the right place) and I don't know where else to turn to for this issue. I had a small oil leak form the water pump and followed SuperMotoRuss tutorial (which worked perfect besides my f*ck up).
When I was putting the water pump back together it turns out I forgot to replace the bolt that holds in the impeller (see picture 2). After a quick test ride (~1 mile) it leaked coolant everywhere and I took it back apart and discovered the missing bolt. See the second picture for the damage this caused.
I have no clue what to do. The water pump appears to still work because since putting everything back together properly, the bike temp stays normal. However, I am very worried about the metal shavings that came off from the impeller. Looks like about 1/16" was ground down. I'm not exactly sure how the water pump works. Would this stay in the coolant system or would the shavings go into the engine oil and cause more damage?
Any comments or suggestions would be appreciated.
Thanks
1 - 1 of 8 Posts
As stated, I wouldn't worry much. Personally I would remove the radiator and back-flush it because that's where the narrowest channels are in the system.
But I'm more concerned where the coolant spilled from when you rode it?
Did it overheat and spit it out of the header tank?
1 - 1 of 8 Posts
