1 - 20 of 33 Posts
what gearing for an R6
also what about a gix 1K? or what changes have you made from stock for VIR, I can guess from that
your man sexy pal
Wiz
why would timmy put on a 49 rear for a slick? Dunlop slicks have a bigger diameter that DOTs, he'd want to go SMALLER on the rear sprocket.
Wiz, I'll likely run a 16x45 at VIR, give or take a rear tooth
Discussion Starter · #6 ·
so stock is 47???? on your ride???
Discussion Starter · #8 ·
for the 1k your best to go +3, although +2 would work as well from what i hear.
plus wow, i would have thought down 2 in the rear
I bought his SBk engine and other goodies. If they were running 17x44 their trap speeds would have been a lot higher, or else they never hit 6th gear
I got 16x48 and Timmy has 16x49 to allow for slicks
fever not knowing his ass from his elbow again.,
TIM has 15x49 ., right now., when he put the 195 slick on dunlop told him to add one tooth to the rear because th tire is bigger you change the gearing.,
i have 15x49 on mine but will be running 15x50 for VIR.,
Fever
Discussion Starter · #19 ·
to sum a simple question up.
Timmy currently up 1 in the rear from stock and going to up 2
Adam up 3 in the rear.
Fever full of shit
thansk ill go 17/45
1 - 20 of 33 Posts
