What type of tubing can i use for the vent on top of the head......( not sure of correct wording )....
The vent out of the top of the head is a crank case breather. The tube should go to the air box, or an appropriate catch container if the air box no longer exists. It may blow oil out, and you don't want that on your tires. Any correctly sized piece of heater hose will work.
Go to home depot/lowe's and you can by the appropriately sized (3/8 or 1/2 inch, I can't remember
)fiber reinforced clear plastic tubing...looks trick and works very well
YAAFM Mod
The clear stuff is fun then you can watch the stuff blowout! More fun than blowing milk out your nose!
Bones
[ 10-12-2002, 12:58 AM: Message edited by: Bones_GSXR ]
