Ok thanks for the heads up. I don’t use it often. Perhaps 2-3 times a yearIf you are using MR12 I would keep an eye on them.
Those are the Venturi system?
yes they areThose are the Venturi system?
Sorry NM I see it now lol
Sweet! Did you get more power throughout the whole band or did it just shift the power to different rpm?yes they are
What did they cost you? Did you put them in yourself?yes they are
Yea man! More power the better! I’m thinking of getting a Ducati or a Honda CBR SP cause they put out over 200 to the wheel! 🤤🤤190ish, not too bad.. I wouldn't know what to do with 200hp, not many straights that long, well unless yea nope
they cost around 500$ and they are very simple to install.What did they cost you? Did you put them in yourself?
And Here in GA we got some nice straights!
Thanks for the info. We do roll on racing every weekend! 😜 Weather permitting of course.they cost around 500$ and they are very simple to install.
regarding the 190whp, they are hard to put the power on the ground, except if you only do road racing.. You wont notice a big difference between 190whp and 200whp, the biggest difference imo is engine and frame behavior..
We do it on a long safe stretch. Just make sure you find something similar. And I have to say the Brembo brake pads have been good!welp, packed out in 6th with 190 imma lil' more concerned with braking honestly..
For sure, braking is as important as power.. I installed Brembo rcs19 corsacorta + hel lines + zcoo ceramic padswelp, packed out in 6th with 190 imma lil' more concerned with braking honestly..
Very nice. So far the stock system has been sufficient. 💪🏻For sure, braking is as important as power.. I installed Brembo rcs19 corsacorta + hel lines + zcoo ceramic pads
that is a cold engine/ tire vs a warm engine/tire not a good comparison. - it should have a little loss then the 5hp should be at the top only (above 13k rpm)
here you go - just grabbed 3 runs from my tests not sure if it was the same 3 butStill waiting for you to show AFR values to show they are equal............
