Hello from Russia!
I studied the topic of high-speed stack intake for a long time, considered options from the store and decided to do it myself.
I won't go into the configuration and dimensions-I'll just show you how to do it.
What you need: 4 high-speed stacks , low ones don't fit, there is a chamfer radius at the joint.
Drank vodka and started! =_))))))
It is necessary to cut 4 high-speed stacks in any way 4-4. 5 mm from the end of the inner surface of the filter box . I made the plane using the machine's grinding wheel.
The essence of velocity stacks mod is that 3D-printed elements will be "put on" over the factory rubber elements.
The plastic was used by ABS. For a week he lay in gasoline-nothing happened to him. Theoretically, fuel vapors can change plastic - I will look at it after a while and unsubscribe!
When the bear printed the stacks, they were slightly reduced in size , so if you do not have experience in 3D printing, it is better to give it to professionals.
If the topic is interesting, I will show you how to set up a fuel card online in real time when the motorcycle is driving on the road. Using fuel module healtech , wideband oxygen sensor and a laptop.
the price of this mod came out at 25$
Photos and videos in the attachment
Administrator-I have some difficulties translating the text, perhaps I wrote in the wrong section. Please, please move it to the right place.
If you have any questions, please write to my mailbox [email protected] or a century.
Cool you have forum!
All health and do not get sick!!!
