Hi,
I checked everywhere .... cannot find it :( My little bunny is more sofisticated than my old R6, and i have no manual to understand the best setup. Right now, I changed the mph to kmh,,,, but i did not want. to.... :) Any youtube video or a pdf or something would be handy.
Also : best tyre pressure on the road w/o pillion?
thanks a lot your help
sorry... new on the gixxa
For road go with that the tire states when it is COLD. Usually in the 40 PSI range. If you're doing some spirited riding drop it down to mid 30's and then fill up again when done so you don't forget. W/O pillion shouldn't add much weight that you would need to consider tire pressure.
However-EDIT. suzuki recommends 36 psi front and 42 rear cold. JUST SAYING.
As mentioned before, 36 psi front and 42 rear cold for the street. 36/36 cold to start with on the track, adjust based observed tire wear... The L1 GSXR600 manual posted is pretty much the same as the L2 750 model, so download that one. I went and bought a factory manual and use the downloaded manual all the time...
