1 - 10 of 10 Posts
I'm fitting some front flush indicators, but I do not want to cut the original plugs from the LEDs.
Can anyone recommend any turn signal adapters successfully? I know HotBodies do some adapters, but buying from the US into UK causes too much import tax.
I purchased these in the UK, but they didn't fit :(
Make your own Simon.
Ping a picture of the connector to this fella and he will have some.
Then just buy some wire and sleeve
  • Like
Reactions: Slicker
Thenthative.
slight resurrection - where did you get the indicators in the UK?
It may vary but in my experience Suzuki likes to use Mitsubishi Ultra Compact connectors for the turn signals. A Google search may find a UK source. I'm aware of Eastern Beaver (Japan) and Cycle Terminal (US). Look at the pics and decide if that's what you need. The flush mounts probably come with a bullet or other connector. You might be able to make an adapter or replace it with an Ultra Compact type. The connectors are cheap enough that you'll probably pay more for the shipping.
Don't know about the flush mount indicators themselves.
1 - 10 of 10 Posts
