1 - 8 of 8 Posts
Discussion Starter #2
And this is the rest.
I'm waiting on a K&N small filter to come in, and I have to paint the pipe running from the dump to my duals. Then I can drop it off to get it tuned.
I starts seeing boost at around 5-6K.
I also decided to install the boost controller before I dropped it off Just in case it can handle more than the gate is set at. I think it's set at 8.
I have a custom intercooler, and It looks a little different than the pics are now.
you are going to loose alot of hp with that plenum. air is supose to flow to the intake, not bounce off and go everywhere. just a pointer ;)
other then that looks nice :cheers
Discussion Starter #6
For best HP gains, air needs to flow in the most smooth/straight path with out sharp non curved bends or walls.
HEY, WHAT IS THAT CLUBredR.COM ABOUT.
are you planning on running lower compression pistons? any other internal upgrades? i'm new to the bike/turbo idea, what are you planning on running for engine management? are you going to have a wbo2 to monitor your a/f's accurately? bigger fuel injectors? love to know some more about the details. looks good so far though!
Discussion Starter #8
As much as I can get out of it on stock internals.
I have a BEGI for sale, for me to use it I have to either tap a return line to my tank, or use an external fuel pump where you tap for it and use the existing feed as a return. PC3 for tune. Stock injectors right now unless I need to get bigger ones.
And I do have a o2 setup on it. A 4 wire o2 sensor.
waiting on a ignition module I ordered from fuelmoto to come in to retard the timing before I drop it off at the shop to get tuned.
1 - 8 of 8 Posts
