Hey Guys,
I am in the process of building a turbo 2013 GSXR 1000, I had a few questions to those of you who have experience building these monsters, First off which turbo are most of you guys running? second It seems that most of the manifolds i'm finding online, are shorties which seems awfully restrictive, So do you have any insight on where I should go for a t3/t4 flange manifold? Same question for the plenum. any tips or information would be greatly appreciated. thank you all and have a great day.
Is this going to be a streetbike or a drag-race only bike?
For street I wouldn't go bigger than a GT28,if it's race only,then you have more choices but remember the bigger you go,the more lag you'll have.
The log-style eBay manifolds are junk,don't even waste your money on one. Nobody really makes turbo kits for the 1000's any more in the USA,so you'll have to beg Richard at RCC Turbo's to fab up a manifold for you or try BigCC in England. Or,if you have the skills fab your own,however if the manifold/turbo sits too low(center line of turbo below cl of crankshaft) you'll need to add a scavenge pump or it will be a crop-duster(burning oil and large clouds of smoke out the exhaust). Same goes for the plenum,you'll have to see if BigCC or RCC will make you one if you can't fab up your own. Again,avoid ANYTHING SOLD ON eBay thats made in China for your turbo build.
That being said: avoid doing business with Jason from RPM Cycle/Velocity Racing,they used to be on top of their game with turbo kits/parts. Not anymore. You've been warned...
The most popular GSXR 1K's to boost are K1-K8,anything after that you're basically on your own trying to fab something up as they aren't too popular for serious modding/drag racing.
After building two turbo bikes,the best advice I can give is to spend the extra money on the best aftermarket engine internals you can buy. Build a purpose built,low-compression turbo specific engine. Bolting a turbo onto a stock engine is a very expensive time bomb ticking away.
I was given that advice by more than one old-timer and I'll pass it along to you. Cut corners on a turbo build&you'll end up hating your bike very quickly.
Good luck :cheers
Good luck :cheers
Thank you for the reply, much appreciated this is going to be a drag bike only, I have no issues spending the money on solid internals. i am going to try and get in touch with RCC, wish me luck. i will try to update the thread with pictures as it comes along
Sounds good,keep us posted w the build :thumbup
Mc-Xpress in Sweden are still doing the odd GSXR 1000 turbo. I am going down to him in a few weeks to finish a Hayabusa Turbo I am building for a customer. Not sure if he have made any turbo for the L3 but it should not be that different from a K8.
Is it even worth it with the L3 @oldgixxer? I thought the engine was pretty "meh" for any boost.
