Ok folks, I'm trying to figure out if these wheels will be compatible to an 05' 600. From what I've gathered they come on a 2018 CBR1000RR and that they're called Carrozzeria wheels. I've attached a picture of them. I've gotten the info the axel torque specs but I can't find anything about the actual measurements of how wide the bearings and spaces have to be. I'd like to think that, that's all I'd need to do to make sure the wheel would fit. Gonna guess that the brakes wouldn't be too far off either? Those are the best specs I could find.
Wheel Automotive tire Rim Wood Spoke
Font Handwriting Screenshot Number Parallel
Font Parallel Number Screenshot Rectangle
If you do decide to attempt the install, the correct diameter wheel bearings are the least of your worries.
Making the correct wheel spacers and finding the correct offset brake discs to work with your application will be the biggest concern.
Also, ensure you get the correct rear disc diameter and that the caliper doesn’t rub with the wheel hub.
I personally am not a fan of “making wheels fit”.
