1 - 20 of 36 Posts
Hi, just got my K5 1000 last thur. I would like to know which TRE is better for the K5 1000.?
I heard that installing the TRE will disable the gear indicator. And does the TRE really will increase the bike performance.
And i find that gear 1&2 for the K5 is a bit slow on respose.
I had problem lfiting my bike in 2nd gear on power wheelie.
Anyone here can help mi with these question?
I can honestly tell you that I have the same problem lifting the K5 in 1st & 2nd gear, compare to my K3.
Aside, I'am also looking for a TRE that will not eliminate my gear indicator and yes, the TRE makes a difference in improve performance.
Discussion Starter · #6 ·
[/QUOTE]
i heard ivan TRE 7 can . It will not disable the gear indicator.
But i do need more info before i get one.Cos it not cheap.
umm mine seems to be fine so far . maybe its just singapore bikes that might have that problems
Pardon for saying, but if you guys are having problems lifting the wheel on the K5 in 1st & 2nd something is wrong
My bike has tried to throw me off in 3rd gear power wheelies several times already
Bone stock so far..............and I am lousy at doing wheelies
Keep in mind size does play a role. I am over 200 pounds and I do not have much trouble keeping the front down at full throttle.
Yeah, weight is of course a factor, but I am at 186 lbs so not that much difference beween us.
I find the K5 easy to lift, yet more controllable in 1st.
Anyways it is the performance with two weels firmly on the ground that counts.
1 - 20 of 36 Posts
