I tried to parallel park a bike the other day but I couldnt find the reverse gear. Has anyone else had this problem ?
Yeah , i found that the easiest way to parallel park is to lean the bike over onto the training wheels and pivot it into position. And hook up a couple of solenoids to a switch so when you want reverse, you reverse machine polarity (positive ground) and turn the motor over so it runs backwards and put it in first and go.
SNAFU
A more low-tech approach would be to fit a set of pedals off of a mountain bike, and simply pedal backwards.
"Yeah, well I'm gonna build my own theme park! With blackjack aaaaannd Hookers! Actually, forget the blackjack."
