I have a lot of tools, but one i do not have is the spanner socket for the rear motor mounts on my 01 600. My service manual calls this tool an engine mounting thrust adjuster socket wrench. Does anyone know where i can get this and what size it is? I thought about sears, but checked their web site and found nothing that would work. Thanks in advance for helping me with this info...
Ryan
Bearded Viking Admin...
Try looking in the GdC store - there are some Gixxer specific tools there
I just looked at the store and there seems to be no tools at all...
Hmm - I have the previous generation 600, but I think they are the same here - you do mean the nut with 4 slots in it, right? You can get it from a Suzuki OEM dealer like Ron Ayers but it's expensive. You can also get a piece of pipe of a fitting diameter and then cut it with an angle grinder to form 4 prongs that fit into the slots. Then drill a hole through the pipe to put a smaller pipe through fo a handle - that's what I did. Or you can get a big regular socket and grind it to fit, that way you can use a regular socket wrench
