Need a jet kit and ignition advancer for my bike, damn thing is sucking down gas, no longer in crankcase either, just burning it to rich, also need a seal for countershaft behind eront sprocket, noticed a slight leak
Discussion Starter · #2 ·
Bobby you have any sugestions, bike runs beatiful at ful throttle, litle hesitant on start up and idle till warms up, tailpipe is pretty sooty black, and I am only getting like 29 mph, used to get 41 in Nebraska, would like that back, also would give me alittle more horses by leaning it up.
Speedy I'd get a stage 1 jet kit if your motor is stock and just has a after market pipe
Factory makes the best kit I think. Ignition advancers Factory makes a bolt=on 4 or 5 degree stator rotor. If your going to keeep your bike for a while might I suggest a Dyna 2000 advancer and you can with this upgrade your coils to 2.2 ohm ones.
Richness is up to the carb gurus and factory pro tuning guide website for mikuni carbs.
Bobbychet
Mine only has 14000, on it I already have a D&D header and pipe, K&N filter, suppossed to have stage 3 jet kit, but dont think so, what about emulsion tubes where to get and how hard are they to put in, all help is greatly appreciated
