1 - 1 of 1 Posts
Hello everyone. I ride an 81 GS850, and recently upgraded my handlebar controls to those from an 06 GSX R600. The original throttle cable is a 47" screw in type, which is not compatible with the new controls. Since I converted to clip on bars, which sit MUCH lower than the stock bars, I don't need a 47" cable anymore. Something in the 42" range will probably work fine. Can anyone tell me what the length of the GSX R600 throttle cable is?
(Yes, I am aware that the GSX R600 uses a dual cable setup, and my carbs use a single cable. I plan to plug the push hole on the control assembly)
Thanks in advance.
1 - 1 of 1 Posts
