when i make sharp right turns on my bike that require my bars to go almost full stop, the cable moves and revs the engine up quite a bit, though i cant tell if its binding or why it is doing this. have any of you encountered this before?
really annoying sometimes...
thanks
Reroute your cables. Some where the cable is binding or caught on something. Take care of this before the problem get worse and you end up with a stuck open throttle going down the road.
Add more "free play in the throttle grip".
YOu should have a good amount of movement of the grib before you feel it start to pull on the cables. If you need to get the right amount of free play feel, just feel it on any bike around.
David
yah i got it figured out thanks, had to do exactly that works good now
