1 - 2 of 2 Posts
Hello
So my gas handle / right hand side throttle assembly is loose. at first i thought maybe the screws had backed out bike is a 06 so i tightened them down , one took really well. but it still will slide a lil bit. i haven't torn it down yet but figured i would ask before hand if anyone else had had this issue and if its easy to fix or if i should be looking to replace the entire unit or maybe just a few pieces individually ?
thanks!
It used to slide around alot but after tightening the screws up it slides but only a little. still id rather have it fixed right.
I think the switch pod has a pin that goes into a hole on the bar that holds it in place. Take off the pod and make sure it's not broken off.
1 - 2 of 2 Posts
