Hey!
I have a problem with my Suzuki gsxr1000 k3.
I was out for a drive, went over a regular fartbump and the old lady went out… the display only had the orange backlight after (see picture), it cranks but no start. Never had this problem before.
I diagnosed that the fuse for the fuel had blown, it was been replaced and the display now work correctly.
Unfortunately I can't get the lady to start again...
I don't get any code in dealer mode. When I try to start, I can get it to cranks but it won't start.
I have tested the following and it works and there is power through:
Killswitch button as well as at the safety at coupling and support leg
Starter relay
Relay for fuel system
Spark plugs (they are clean and intact)
Starter motor
Fuel pump (prime when ignition)
The battery has 12.7V at rest and when trying to start it drops to 10V. Unfortunately, I don't have a battery tester, so I can't say for sure if the battery is ok.
I'll get a new battery tomorrow and put it in to see if it solves the problem.
Do you guys have any suggestions what could be causing the problem, I'll give it a try tomorrow?
Thank you!
Starter relay
Starter motor
Thank you!
