1 - 1 of 1 Posts
Gsxr 750 2002 I took the spring loaded stva sensor off. How should I put it back on? Do I advance it and turn it back counter clockwise to load up the spring? Is there a way to calibrate it? Or should it go back to the stock marks? When I turn the key to the on position is it supposed to open all the way then close then slightly stay open? Help would be greatly appreciated. I'm new to the forum so hopefully this is in the right spot. Thank you!!
1 - 1 of 1 Posts
