1 - 8 of 8 Posts
Just got a PC III USB today and was wondering if anyone else has installed one and how they got the connectors off the FI under the tank. Is it easier to remove the tank than propping it?
unhook the 2 connectors under the tank. beware that gas will come out so put a rag under the fuel line. there is a long bolt that the tank pivots on under the seat area. remove it and the tank will come off.
the connectors on the injectors are a bitch to get off. just pinch them really hard and they will release.
You don't need to remove the tank...just put it on the prop. It's a little tight and you might bust a knuckle, but it's better than pulling the tank.
Take the seat off too. Makes it much easier to prop the tank off.
And yes, I found the connectors to be a bitch too, but they're "quickrelease", so they keep the gas in the tank and not on your engine.
1 - 8 of 8 Posts
