Your help would be appreciated!
I have an integrator, and while my right side directionals pulse at a normal clip, the left's pulse is twice as quick. Like when one of a side's pair burns out. Does that mean I need a resistor/capacitor in-line somewhere?
Also, my directional indicator on the gauge cluster works intermittently. Anyone know how to troubleshoot the cause, or do you figure it's directly attributable to the integrator?
Uhhh... the wonderful world of the electrical nightmares...
No, actually if you have a manual, you may want to look up the diagrams for the wiring and then the voltages of these circuits. First and formost is look for any burned out bulbs of course.. and make sure their terminals or sockets are free of "any" corrosion as that can raise the resistance and pop bulbs and maybe make them act irradically. Then take a multimeter and test connectors for anything that's out of spec and isolate the problem to it's source.
96GIXX, Gotcha.
Thanks. And yes the front two flush mounts (may draw differently then stock)are not burned out, as well as the integrated tail light.
