1 - 10 of 10 Posts
Has anyone done this? Is this easy? Are both sets identical?
He Who Touches Himself
So what exactly makes these brakes better than the GSXR's?
Here is your "R"
Guys if you want the ultimate in braking dont waste your money on calipers... Stock calipers are more then good, the master cylinder is the shitty part. I would buy a Brembo master and steel braided lines.
Thats true,i second this.
About the rear caliper, i dont know where to grind,i only see the front calipers mod but i guess it should be the same unless the bolt pattern is different.
you just need to clear where the rotor is spinning on both ends of the caliper.
I'll go with that. I was told the same thing by Crescent Suzuki and I would say they know there stuff. I was going to go with the K1 1000 6 pots on my 750 but I was told NO go with the Brembo Master Cyl.
Who the hell uses the rear brake??? I don't....
1 - 10 of 10 Posts
