1 - 20 of 31 Posts
Will any of you blue bike owners tell me if the SUZUKI decal that is in the side of bike is under the clear coat or can if be removed easily?
Will cause damage, it is under the clear coat which you have to cut around the decal. Are you going to replace or ?
I don’t know. Maybe live with it when I get one soon. I just really hate the big ass letters on there.
Lots of options
It's under the clear, so your options are to sand it out, if it's a vinyl decal under and you don't damage the base coat respray with a good 2K clear, sand 1500->2000->3000, then 3 stage buff back to shine. If it's a painted decal it's likely the absence of a base coat in that area so look to be respraying the entire tank.
Cheap ass way, buy whatever color vinyl cut to size and cover it up.
What's the best method to remove all the blue-colored decals on the 2018 Matte Black 1000?
Thank in advance.
570635
Lots of options
Short of a new paint job, buy race plastics in black, pull off stock and tuck away to remain in mint shape until the day comes you want to sell it, put factory plastics back on and sell the race plastics.
This is by far the best advise.
Race plastics remove your lights and signals making them illegal for the street, correct?
I'd still like to hear the best method for removing the decals from the factory plastics.
Lots of options
Sorry I thought it to be common sense that you would modify race plastics to use the factory lights.
You have one option, sand down the decals and repaint, they are under the clear, you cant just "pull them off" so your option and only option is to repaint your entire bike.
With all due respect, only the decal on the metal tank is under the clear coat.
Apparently, it's not a matter of common sense at all.
Can anyone offer anything constructive or helpful regarding removing the factory decals?
Thanks.
Thanks.
They cannot be removed without damage. You have to break through the clear coat to remove the decal. Paying attention to "break ".
You’ve been asking this question in multiple threads for what seems like a while now. Take a new razor blade and cut around the outside of whatever it is that you don’t like. Then stick the blade under the decal and try to peel it up. If you actually get it off that way then you can look at what is left and figure out a solution.
There is going to be a void left.
You can sand down everything else to match the base and repaint. (Recommended)
You can bondo the void left by the decal & clear coat removal, then sand & paint
You can bondo the void and sand and vinal wrap
Insert whatever other option you want to do here, because it involves some form of sanding
There is no other way. Everyone keeps telling you this and you’re not listening.
You realize that all of the decals are NOT under the clear coat, right ?????
The only decal UNDER the clear coat is on the metal part of the gas tank.
I'm assuming all I need to do is take a heat gun, or even a hair blow dryer, to the decals and peel them up by hand.
But, I was hoping to hear from people who have done it themselves already.
Maybe you could reach out to this guy. He definitely swapped some decals around.
Nope. I don't think anyone is talking about the gas tank decal, which is the only decal under the clear coat.
Yes got it, it`s under the clear coat, and yes it`s the only one under the clear coat. " You can`t remove with out damage" you get it ?
1 - 20 of 31 Posts
