Anybody know where I can get the middle gear between the STVA motor and the big plastic gear? Or if I can just use a generic servo gear that about the same size?
No it's a direct mount. It's a 2003. Do you know what STVA will work. I found a 2003 1000 for $90. It's the same part number. But I don't know if the STVA I have is the correct one. I sent you and email through eBay explaining everything.
So you have bigger problems. The spindle for the gear is part of the housing. Your spindle is broken off. Sorry to be the bearer of bad news, but you need a replacement STVA. I'd be curious to see how similar it is to the one I have.
Looks identical unfortunately someone hardwired my STVA so it's going to be an even bigger adventure. I have been looking for a new STVA just can't seem to find one that isn't $250. I can't afford that.
They cut 2 wires out of the both connectors that's it. But it looks like all keihin are the same even the Kawasaki's. Same rivet pattern and everything. I'm going to order a Kawasaki one and see if the bottom casing will fit mine. I found one for $50 on eBay.
1 - 14 of 14 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
