1 - 9 of 9 Posts
firstly, this bike is pissing me off.
now, the bike starts (after i replaced the blown ignition fuse).
but, displays CHEC on the temp read-out.
rev counter's decided to go to sleep
but fuel light is not alight
can anybody help me ??
when turning on, pump spins up ok, but the fi light goes out immediately afterwards instead of waiting till the bike is started.
help, please.
Discussion Starter · #2 ·
dont worry, dont panic.
it's me, i'm a fuckin twat.
after playing with it for ages, i went back out to either mend it or give it a good trashing with a big stick.
the green connector on RHS from the rpm sensor thing wasnt connected.
that was why !!
hate this bike
Have you tried to put it in dealer mode? Sounds like the tach pickup is not working correct...
that was why !!
hate this bike
<font size="2" face="Verdana, Arial">Fine then I didnt want to help you anyway!!!!
Did you check the wire to the temp sender? I think it's on the right side near the bottom of the engine. That might be the cause of the temp gage issue and could be part of the checks the system goes through for the FI light -- not sure. The only time I've had a tach not read is when I lost all power. Why did you have to replace the ignition fuse? Whatever shorted it originally may still be the problem.
Discussion Starter · #6 ·
fuckin spot on john !!
wish i'd have posted this earlier for you lot instead of shouting and swearing at the heap of crashed shite outside.
i tried the dealer mode but it didnt do anything.
did a few searches on here and it dont come on if the fi light is not lit apparently.
thanx anyway john
Well I am glad it is working for you..
Discussion Starter · #8 ·
yes you did john
now john, can you get a 2K gixxer cuz i want one and will eventually need some advise on it
so if you get one now, by the time i have one, you'll be clued up on those as well
Discussion Starter · #9 ·
thanks for the response craig also, that was what i was gonna check next untill i noticed the connector.
no idea why the fuse blew though.
you know, this site is very good indeed.
the mrs only allows me 1hr a night after the chat room female incident (dont ask), and i spend that hour on here..
1 - 9 of 9 Posts
