I took the stock steering damper off of my K7 and installed an Ohlins damper. I also purchased a device from ebay (danosperformance.com) called a steering damper eliminator (which eliminates the code generated when you disconnect the factory steering damper).
I learned a couple of things that might help those interested in doing the same mod and also save some time. :cheers
First, to get to the steering damper, all you have to do to remove the stock steering damper is remove the (2) 10mm bolts holding a semi rectangular black plastic plate on the forks right above the front tire and directly below the steering damper. You don't have to take all of the fairings off (like I did :blink) Then, remove both fairings from the left side of the bike. Also take the black air intake guide off (1 pop rivet)
Remove stock damper, install Ohlins, super easy. I reused the nut from the stock damper to secure the bolt supplied with the Ohlins on the banjo fitting. Before you tighten down the two hex head screws on the center bracket of the Ohlins, loosely attach the Ohlins and do some full side to side turns with the front wheel to ensure full motion.
Now for the Steering Damper eliminator. It would have been a 5 minute job but the instructions were vague with respect to the correct plug to attach the eliminator too. After reading the instructions, I immediately zero'd in on the factory steering damper solenoid plug (that is not the one you want). The one you want is on the left side of the bike right under where the intake channel was sitting and right next to a big clear wire bundle cover. The white plug has two wires on each side. The side you want has a brown and white wire. While pulling slightly on the back of the wire, stick the nail into the front of the connector as shown in the instructions (If you are yanking on any part of the install, you are doing something wrong, the whole operation only requires light pressure). The male wire pulls right out of the back (do this on both wires) Then transfer these two wires to the supplied connector. Take a minute to study how the wire "clicks" in. The rest is pretty easy with the instructions. I just wasted a lot of time taking off too many fairings and screwing around with the wrong connectors.
Track day tomorrow (wx permitting) Can't wait to try the Ohlins. I had too much wiggle under hard acceleration last track day with the factory damper... YMMV
