I have 07 gxsr 600 and i change my stator 2 times in 2 months then i change stator Rectifier starter and battery...rode for a week and stator is bad again whats causeing the stator to go bad
Do you have a copy of the manual?
Have you done the charging system tests listed?
When you replaced these parts did you also check the wiring in-between?
Did you replace with OEM parts, or aftermarket?
Many cheap aftermarket parts are made to incorrect specs and do not work correctly.
Did you use the provided connectors, or did you hard-wire the stator and RR?
If you hard-wired, did you solder, crimp, or twist the wires together?
OEM replacements or aftermarket?
Check wiring for continuity
