I just spent this past weekend swapping Frames on my 96 750.
Long Process and I'm happy to now be done with all the mechanics.
Unfortunately now that I have everything back in its place (except fairings) when I turn the key to Run while it’s in Neutral (with clutch disengaged) the fuel pump won't turn on and it won't attempt to start.
I am getting power to the gauges and I would assume lights (though I didn’t connect)
I checked the usual: Kickstand switch and engine cutoff switch connections just checking the connection (no voltmeter or anything) everything seems to be connected and in working order. I'm not sure what to check now...
If someone can lead me into the right direction I’d greatly appreciate it.
Racer: No, Sorry if I was unclear: It will not Crank at all as it sits. The Fuel pump won't even start.
I was saying that it was in Neutral with the kickstand up and had the clutch in on my trials just to void out that it couldn't be the kickstand switch.
FYI The headlights and taillights are both completely functional...
