So here’s some history my 06gsxr 600 wasn’t running good an kept stalling. So I get it Home an now the relay only makes a tick when I try to turn it over. From my research I believe it has to do with one of the starter idle gears. I have no idea where to start an was hoping someone could lead me in the right direction
+1 to charging system, just like cars if you are just hearing a click at ignition request, good chance the battery is dead. Do you have headlights, gauge cluster "boot" on accessories power, etc? What about when the flashers are on, does everything dim? Also a multi meter will tell you battery voltage.
It's likely to be something electrical long before the starter bearing and gear have an issue. Put a volt meter across the negative pole of the battery and the starter positive and try to start it. See voltage getting to the starter?
Went through all the electrical an I’m getting power to the starter. Checked the neutral safety an also new battery. Tried to bump it an just locks up an skids. I’m assuming it’s seized up......
Take the spark plugs out, put it in 6th and see if you can turn the engine with the rear wheel.
