https://youtu.be/hekRZDy9Sfw
Can't find a fix for this. Replaced Sparks, checked idle, checked air filter. This happened post valve adjustment at a shop (2nd time at any shop). All other work I do myself. 32k miles no mods.
Let me know if I'm an asshole.. as long as you give me advice I don't give a fuck
Do you have access to a service manual?
There are some troubleshooting charts in there that would help.
Have you done a fuel flow test?
Have you checked for vacuum leaks?
Moderator
Was there an issue that called for a valve check?
In the video you say it had 7800 miles, but in the post it says 32k. Which is it?
Did it happen immediately after the valve adjustment, or did it work fine for a while? If immediately, the adjustment is obviously suspect; if not, how/when exactly did it start to do this?
