This has probably been asked a thousand times before, but a quick search failed to find an answer.
Where is the simplest location to tap into a switched 12volt supply on W reg 600 SRAD?
Trying to avoid too much effort, such as fairing removal, etc.
That’s Mister Moderator To You ....
I would think your decision should instead be based on where you want to install whatever it is that needs power and how much amperage it will draw, as that will affect the fuse associated with that circuit.
If something as basic as removing fairings is a factor that will affect your decision, you should bring it in to a mechanic.
Perfectly able to do the work. Just lazy!! Power consumption is pretty low. Camera system. Supplied power leads were just about long enough to run it straight from the battery, so that's where it went. Wasn't really an issue until my regulator/rectifier went rogue and, regardless of settings on the recorder, it kept more or less continually running, killing what little was left in the battery between charges.
New regrec went in last night. Perfect. Just need a definite on/off for the supply to the recorder.
