I was wondering if I just go +2 in the rear sprocket will I notice a considerable difference over stock or should I just go -1+2??? I am trying to gear my 04 600 so it will be easier to wheelie but I don't want to lose too much top end so would you guys recomend just +2 in the back or should I just go for the -1+2... THanks for the info in advance
-1 in the front first if you haven't already
A 600 will wheelie without gearing changes
-1 +2 would definetly do it
If you are just screwing around with gearing to find what you like I recc. staying with the 525 OEM sizes. Saves $$$
I know that the 6's will come up but I want it to come up and stay up... hehehe... Just wondering if +2 on the rear will do it or should I go -1 in the front??? I still want my bike to basically be like it is now but with a little more torque on the low end to get the front up in second gear... What do you guys say... +2 on the rear? -1 on the front??? or -1+2??? Thanks
808fastbikes
Cock Thumb, or Thumb Cock? You decide.
808fastbikes
gearings not gonna help keep the front up, you gotta learn how to balance it.. your bike will come up fine with a dip of the clutch, i could rip it up sitting around 50 mph, cllutching 35mph or so. bouncing 3rd standup is even no problem and can be ridden for miles with stock gearing..
808fastbikes
-1 first
$20 mod
if that doesn't do it then try +2 or more in the rear
Fuk it go -2 up front +13 in the back, flatten the tire and then it stay up all day
I ride with +2 on the rear and there is a noticeable difference over standard. But it's not overly harsh. The general consensus seems to be that -1 on the front = + 2 on the rear. If that's the case, then it shouldn't really matter what you do.
